Hudson wheels and radial tires
TwinSupercharged
I have a 1951 Hornet with 15" wheels that I believe are
the stock wheels. They have hub cap clip holes but no clips. I want to run
radial tires. Are the Hudson stock wheels compatible with modern day radial
tires?" Performance and safety?
They work just fine and have been running radials for years. A 225/75R15 is like running a 7.60-15 or H-78 15. A 215/75R15 is close to a 7.10-150
My C8 is using radials and its original wheels, tubeless!0
I replaced my bias ply tires with Diamondback Auburns in 215/75R15 on my 1951 with original rims. I use tubes as a precaution against leaks. Everything about the ride is better! https://dbtires.com/
+1 but no tubes - great tires - very priceycchancel said:I replaced my bias ply tires with Diamondback Auburns in 215/75R15 on my 1951 with original rims. I use tubes as a precaution against leaks. Everything about the ride is better! https://dbtires.com/0 -
Ken, what do your Chrysler 15x7 rims look like? Can you use Hudson hubcaps on them? Any idea what Chrysler model & year they are from?0
