Master cylinder
Is the Jet master cylinder the same as the full size Hudsons?
Thanks
  • They are a different part number, but are the same size, so it should fit.
  • So - you can use a Senior model  master cylinder on a Jet, but not the other way round it would appear.  I'm sure the bolt pattern is the same.
  • You are right, (as always) Ken.  If you can find an original part, use it!
