outside door rear view mirrors
I have been looking for these mirrors that Hudson used new and exclusive rear view mirrors parts and pieces to make 2 mirrors but to no avail. So I finely bought 2 mirrors from Paul Schuster .They look good but hopefully they will owrk on passenger side. Any suggestions on installation. Ray
He usually includes a template for installation. I have installed a couple sets of his mirrors.
Have someone hold the right one on and make sure it will turn CCW enough so you can see the right side of the car. Mine are not his {?? didn't install these} but using a WalMart cheater piece to see out back( also have backup camera located on the rear tag screw.)
Edit: The mirror would not turn far enough to see straight back; the cheater is made with angle cut on back; not just a convex, and is 4.5" as I remember.
A good solution is the backup camera located above the 'first 3'; monitor on caddy on hump. Camera works in 2 modes, 1: on continously, 2: on only in reverse.
Scott Drake does make a mirror for a 65 mustang with the convex mirror already in it. A little pricey, but an option.0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
