‘47 212 engine water distribution plate and pipe
                    Here is something that has bothered me for more than 20 years and I just have not asked about it.
The pipe coming up off the water distribution plate on my ‘47 Hudson 212 engine seems to be a little off. It puts a slight dogleg in the radiator hose that connects the pipe and the water pump. It looks like it was just manufactured incorrectly and should be pointed a little more towards the engine block and then the hose would line up.
Has anyone else seen a hose with a dogleg like that? If it is incorrect, now would be the time to replace it before I go to the effort of bead blasting, priming and painting it.
If it is incorrect, does anyone have a correct one they would be willing to sell?
Thanks. Tom
The pipe coming up off the water distribution plate on my ‘47 Hudson 212 engine seems to be a little off. It puts a slight dogleg in the radiator hose that connects the pipe and the water pump. It looks like it was just manufactured incorrectly and should be pointed a little more towards the engine block and then the hose would line up.Has anyone else seen a hose with a dogleg like that? If it is incorrect, now would be the time to replace it before I go to the effort of bead blasting, priming and painting it.
Thanks. Tom
            Thats funny, my 36 T 212 hose pipe is off too but in the oposite direction. It makes the hose dogleg towards the engine head!0
Quality control at the factory needs to be tightened!
            I keep writing to the factory, but no one responds. What’s wrong with those people?
Tom0 -
            Perhaps they are still under lock-down!0
 - 111 Hudson 1916 - 1929
