Voltage regulator
hudsonsplasher1
This may have been discussed before but is it normal for the voltage regulator to vibrate at low rpm's? Generator checks out ok, and the vibration goes away (or just can't hear it) at higher rpm's. A electrical engineer friend said they are designed this way, though my other Hudson's don't do this. Anything to worry about, or should I just leave it alone? Any help much appreciated.
Gene.
Gene.
A side note, maybe it's not the correct regulator for the car. Anyone know what is the correct one for a 49 Commodore 8 is?0
The correct voltage regulator for your 1949 Commodore is an AutoLite VRR 4001A with 4 terminals.0
Thanks Lance, that's what I have.Lance said:The correct voltage regulator for your 1949 Commodore is an AutoLite VRR 4001A with 4 terminals.0 -
I think that I have a NOS one if yours is toasted.0
7XPacemaker said:I think that I have a NOS one if yours is toasted.
Thanks for the offer, what are you asking for it?0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
