Asking about 1954 jet wheel size ?? are they the same as FORD !!??????
Just want to make sure I’ve been told the bolt pattern on the 54 Jet are the same as a Ford ????? 15x5 5 lug
thank you
thank you
same as the 5 on 4-1/2 pattern of some Ford and Dodge. The ford and dodge wheel will not have the hole for the locating pin0
Jet wheels came in 4” and 4-1/2”0
Thank u sir54coupe said:same as the 5 on 4-1/2 pattern of some Ford and Dodge. The ford and dodge wheel will not have the hole for the locating pin0 -
awesome thank youKen U-Tx said:Some Mopar 15 inch wheels DO have the hole for the locating pin........http://thewheelsmith.net/wheel-catalog/mopar-wheels
