‘47 Hudson Grille and a lesson re-learned.
When I had the stainless strip in position and tried to install new 10-32 nuts on those machine screws, they didn’t fit.
uh-oh. What’s going on here? Time to get out the thread pitch gauge. It turns out that those machine screws are size 12, and not only that, they are 12-28.
The lesson re-learned is simple. Bag it , tag it, and never throw any of this old stuff away. It might turn out to be something difficult to replace even though it looks like something very common.
Tom
Interesting as my 47 pickup did not have the metal strip in these grille pieces. IIRC the trim was installed using some clips which snapped into the back of the trim. Anyway I ended up using the more readily available and slightly more modern 10-24 stud clip with a spring wire. My hood center molding has the strip with studs however. Likewise with the actual grille pieces I used two different sizes, the 3/4" with 10-24 stud for the curved pieces and a 5/16" for the smaller middle strips which seem to work perfectly. Many auto body supply businesses have these clips0
fastenall as well as many other places list the correct size nut - you will simply have to order them.0 -
BTW, the fasteners that go inside the curved grill pieces are still available in the online catalog from restorationspecialties.com0
That would be these clips from Restoration specialties. They are on page 134 of the 2015 paper catalog that I have from them. My old ones were pretty well rusted away so I ordered all new several months ago
Tom0 -
That's what I was talking about. Wish I had seen those before using the gm/ford type of clips but the newer style seem to work well also0
- 110 Hudson 1916 - 1929
- 176 The Flathead Forum
