Removing an engine from a 48 Hudson
Doctorvaux
Hello,
I need to remove the engine from a 48 Super six. It has a non original wide block 262 fitted with an overdrive transmission. If I remove the radiator, front grille, can I avoid having to remove the hood ? I intend just removing the engine on its own. Thank you for any advice.
People have different ways of pulling engine from the stepdown. I wouldn't count of not removing the hood. Remove radiator and latch panel and you'll have clearance. I pull engine and trans together. One of the risks of leaving trans in the car is the throw out bearing seal. You could ruin it coming out and or going back in. Alignment of out put shaft to the clutch is critical. Has to nearly perfectly aligned or seal will be ruined. That causes more work and expense. If you don't have a shop manual, recommend getting one.
Wish you success
Kim
I doubt that you would have enough lift with the hood on.0
Thank you both for your advice, much appreciated. I do have a shop manual.
Also Suggest using a lift leveler. connects to 4 points on the engine and allows being able to change angle coming out and going back in. Makes it easy for one person to do the job. I don't like help, can't control helper but can the leveler.
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
