35 T tire / tyre pressures.
Hi All,
The Procedure Manual and owners manual for the 35 T shows the "minimum" tire / tyre pressures as 22 PSI front and 28 PSI rear. Both seem low. I'd like to hear what others may be running.
28 front, and 32 rear on my Essex, have been doing that for 64 years, and tyre wear is even. That is factory recommended. On Jet I do 28 all round. On your car I reckon 28 and 30 would be fine. Tyres are different from 1935, when they were 6 ply and camvas belted. Modern tyres are Nylon. Be guided by how the car rides and steers, and on tyre wear. Should wear evenly across the treads. Trouble is few of us do enough miles per year to actually ascertain that.0
Thanks Geoff. Your recommendations seems much more plausible for a starting point.0
80 years on tyre technology has changed, be guided by the inflation pressures printed on the side wall.0
Geoff, Bob, Indeed you both had the good info. I'd purchased new Goodyear Diamond tread tires and never looked at them thinking the original dies would have been used to make them. The original tires didn't have such data on them and I have no idea how old they were. The new one have "4 ply nylon cord" and "32 psi max" along with load rating etc embossed on them.0
You will find the ride fairly hard with Nylon cords if you have too much pressure in them. I would go with 28/32 initially and see how it handles.0
650x16 tyre pressures. The sidewall on most tyres only states the max allowable cold pressure. You would think that somewhere in the manufacturer's literature there would also be a minimum allowable pressure which is maybe - and I'm guessing here - 10% or 15% below the max. That would be the range you have to work with.0
This era had more weight on the back, not the front. That is likely part of the reason the recommended rear tyre pressure is more than the front.0
You’re right... my 36 Hudson sedan weighs 3280 pounds. 1400 pounds on the front wheels, 1880 on the rear.terraplane8 said:This era had more weight on the back, not the front. That is likely part of the reason the recommended rear tyre pressure is more than the front.0 -
If you were to torque the lug bolts on a 35 T what would it be?
OR would it fall under "good mechanic tight"0 -
From bolt suppliers web pages the max recommended torque on an unplated grade 5 bolt 1/2"-20 is 85 ft.lb. which is a 55 lb pull on an 18" socket handle. Absent a torque wrench "good mechanic tight" sounds about right.0
- 112 Hudson 1916 - 1929
