Fuse box wire locations 23 Hudson
I am trying to add turn signals to my 1923 Hudson. I have to attach the power supply
through the fuse box using a fuse spot from an existing connection. The directions say
do not connect to the ignition switch terminals. Does anyone know the items connected
to the terminals or do I have to chase down each wire?
Robert
I would connect to the live side of any of those fuses terminals, and run an inline fuse to your indicators. To find which is the live side, remove the fuses and check the terminals with a volt meter.0
Thanks GeoffGood advice. The kit comes with a inline fuse assemble.0
