Oil Check Valve/Oil Pressure Warning Light
Old Fogey UK
Further to my post earlier today, I've taken the oil check valve off, disassembled it and cleaned the sludge out.
Everything inside looked OK but the oil warning light is still staying on when I start up.
Could the problem be related to the wiring or do I need to take the oil pump off and have a look inside that also ?
Obviously, I'm loathe to run the motor until I'm absolutely sure it's not an oil pump/flow problem.
Disconnect the input to the pressure switch, and start the motor. the oil should pulse out. If not the problem is in the pump or pipes.0
If the oil light wire is shorting before it gets to the oil pump that will give you a permanently on oil light. If your car still has the original wring that is a distinct possibility.0
Thank you both very much.
I will follow up your advice.0 -
The oil pump is working. So it must be a short. I can't see an obvious wiring problem, so it's going to be a call to my local car electrician - who, fortunately, is a classic car owner himself.
In the meantime, I'm assuming it's safe to use the car.0 -
Can you use a test light? I had to replace a bad sender.0
Disconnect the wire from the sender. If the light is still on, the fault is in the wiring, if it goes off, then it is the sender.0
Geoff said:Disconnect the wire from the sender. If the light is still on, the fault is in the wiring, if it goes off, then it is the sender.
If it is the sender, they're available from the ROC.0 -
I disconnected the sender and turned the ignition on and the oil light came on but the generator light didn't.
Reconnected the sender wire and turned the ignition on - both lights came on.
Wiring problem ???0 -
That is weird! The ignition switch terminal goes to both the oil and generator lights. What happens when you disconnect the generator light wire from the relay? Whatever, yes, you definitely have a wiring problem!0
I'm calling the auto electrician this morning !0
Do you have a wiring diagram? I can scan and send if you need one.0
Minor diversion, looking at the 34 H&T and 35 T Special wiring diagrams I have it looks like the coil is part of the ignition lock. Am I understanding that correctly?0
Thank you all very much for your advice but, at the end of the day, I'm a simple-minded lawyer and a barely competent car restorer and the mysteries of car electrics are way above my pay grade.
I'm leaving this one to my local car electrician who is a classic car owner himself !0 -
When he's fixed it, I'll let you know what the problem was but, if past experience is anything to go by, it will have been something I did wrong !0
The electrician is coming next Tuesday.0
- 105 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
