Super Six (1930) oil pressure...
My indicated oil pressure is about 1 1/2 lbs. The lines to the rear bearings and timing chain feel warm but not hot to the touch after extended idling. Is there a way to adjust the pressure or check the flow? Thanks in advance for your help...
Leave it alone. So long as it is showing any pressure at all it is working.0
