Oil pressure switch
I've got a '54 Hornet with a set of Clifford headers and I need to replace the oil pressure switch but I'm having a hard time trying to figure out how to get access to it. Can you get to the switch by just removing the fender side shields or what? Thanks much.
Tim in WI.
Tim in WI.
Removing inner fender will help a lot but also try coming in from the front of engine between the headers to reach in.0
I will look into that. Thanks.0
You don't have to remove the complete inner well the section of fender well by fire wall unbolts giving access to oil pressure switch0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
