head gasket
hi everyone ive noticed a little weep of oil on the head gasket.
where can i buy a new one . thanks in advance
1951 hudson commadore model number 6a 43410
engine number 43410
has 262 on top of head to the front ,to the rear of head 304821 2 cwc flat head steel .
engine number 43410
im in the united kingdom .0
Well there is no oil in the head at all, so maybe it’s just old nasty coolant? Dale Cooper and maybe Lance Walker in the US should have a new gasket. Not sure about the UK. Also try to re-torque the head and see if it helps. I’ve also used a good stop leak added to the coolant to slow the leak, hopefully it’s not going into the cylinders.0
thanks for your advice chaps.it is only a nothing wet patch, but i no its there so will order a gasket. whats the tourqe on the head bolts please as will give that a check for now.0
- 112 Hudson 1916 - 1929
