Differential needed
I have a spare one in Australia. Freight is a killer0
I may have to swim for it!0
I have a complete rear end from a 46, that I removed it in July. As far as condition all I know is I drove the the car some and it seems ok. I am in Cortland OH. Where are you located? Thanks, jsalbert7110
I am near Fort Wayne, IN. But I do travel to your area. Please check the ratio 4 1/9.
I will check0
I am pretty sure it is 41/9 ratio, but I don't have the puller to remove hubs ,pull differential out and count teeth. Make me an offer and come pick it up. Thanks, John0
You can identify the ratio by turning the wheel (brake drum) one revolution and counting the number of turns the driveshaft yoke turns.0
Thank You all for looking , I have located one nearby.
You are welcome0
- 112 Hudson 1916 - 1929
