remove wheel
i tried almost everything to remove right rear wheel to check brakes, wd40 and other snake oil products to loosen it up ,
tried a oversize nut that i paid like 35$ for but the threads were wrong to use a pulley puller so i returned that,
while having a beer in front of wood stove i had a brain wave....... i have a complete spare drivetrain... so why not take a spare hubcap ,drill a hole in center of it and use the cap as a puller, worked like a dream... and still have 3 good caps left... and the HOLY one is part of tool collection...
Are you speaking of removing the BRAKE DRUMS?
If so, see Ken Cates' instructions at his StepDown website: https://hudsonrestoration1948-54.com/Brakes.htm
On the left side of the page, click on "Removing rear drums -- StepDown".
Remember, do NOT remove the axle nut entirely, before pulling the drums. Loosen it slightly (1/4" maybe?) so that -- when the drum breaks away -- it is stopped by the axle nut before it hits you!
This thread has a picture of the hub puller:An impact wrench can be used instead of the "dog bone."0
And yes, there’s a jack stand under the axle
You can always use an air or electric impact gun on the large but of that puller, quicker and easier than a hammer0
no just to remove the whole wheel from the tapered spindle... i got it off using a puller and will be applying never seize on that puppy.... the brake drum is attatched to the spoked wheelJon B said:Are you speaking of removing the BRAKE DRUMS?
It looks like we all assumed you were working on something much newer.0
Marius I don’t think you want to put anything on that tapered axe as far as lube/ anti seize, the taper is a interference fit and you will be more prone to shear off the key
just my opinion0 -
thank you, it was a thought and apparently not a good idea... thank you for your wizdom0
