Loose steering. 1928
Marius
the nut and screw on the side of the steering box is screwed in snug but still have play in wheels,
the double nut on top of steering box what does it do??
the wheels are both tight as far as i can tell ... move left to right and the linkage seems to be loose right at the steering box
There are specific instructions to adjust the steering box. Do you have an owner's manual? You must remove the drag link, and check the drop arm for play in th eposition of least movement. the box is adjusted for up-an d down movement of the shaft by the bolt on to of the box, for side-play of the cross shaft by the screw on the inner edge and for mesh of the worm and sector by the eccentric on the outer side of the box.0
i do not have a owners manual , i would love to get one.... thank you0
I downloaded ALL 268+paged manual for 26 to 29 essex
figured out the loose steering problem ,it's a nut that's slightly offset on the steering box, thusly working like a cam to tighten the play that wasn't adjusted since probably 1928. now i can probably hit 45 MPH.... eeeehhhaaaa... can't wait for the snow to melt.0 -
Ha ha.. Just remember the hudson law.. Adjusting one item leds to a problem elsewhere.... Ie your speedo will probably snap... Only joking... Enjoy the cruise...0
The club website has links for manuals.0
Original poster has found answer to his question. Discussion closed to further replies.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 604 Vehicles
