1938 country club
i have the original under running board radio antenna complete in amazing condition which side does it mount to ? guessing drivers side but not sure. thank you
Hi Paul it goes under the drivers side running board there should be some clips that hang down from the running board at each end that the antenna hooks on to I have seen cars with one under each running board for more range with the AM radio.0
I would expect a Country Club to have the radio with antenna under both running boards. I rebuilt one many years ago on a'36.
thanks! Park some of the rubber coating over the wire is gone is it a must that the complete run of wire be encased? where did you enter the body with the wire to meet the radio?0
By the way, the shop manuals have sections with drawings on the installation of factory radios. If you don't have access to one, the Club on-line library may have one you can download. (Go to the homepage and click "library", if you're a Club member)
As to the rubber coming off the wire, can't you replace it with some modern rubber-coating wiring?0 -
thanks Jon yes it can be replaced.0
yes i have been in the club since 1987 . is my forum log in the same for the home page ?0
I think if you can get to the H-E-T Forum (not the Open Forum) you would have full use of the H-E-T website. Anyway, try it!0
Paul , your login id on the HET website is "coolsen". I can see a password reset was done yesterday for you but the last time , at the moment, you accessed it was August of 2020.
If you are having problems drop myself or Aaron a note and we can sort you out0 -
There was a fair bit of the original wire under the car, especially the crossover from left to right. (As I recall, there was a splice at the center underneath). The best match I found (and used) is thirties/forties black spark plug wire. It looked identical to the original. I think it's still available in bulk from a Ford restoration source.
- 111 Hudson 1916 - 1929
