installing running board rubber
2manyprojects
1938 country club is now ready to attach rubber to the running boards. what brand and type adhesive have you guys used that works well and any tips when applying ? thank you paul
Rough up the back side of the rubber with 80 grit sandpaper. Glue down using contact cement. I like the solvent based stuff (not water base). The contact cement I used, I bought from McMaster Carr You need LOTS of clamps0
Plan the process thoroughly before you start, get all your clamps and clamping boards sorted.
Do a full dress rehearsal of your clamping set up.
In addition to roughing up the back with 80 grit sandpaper wipe down it with plenty of acetone to get rid of residual release agent.
I like Sikaflex 227 for the adhesive, its a urethane which means it sticks like exretia to a blanket. Its a slow cure and has more than enough working time, leave the job clamped for 24 hours.
This is a 35 running board having the mat glued on.
they have a white and a black sikaflex 227,how many tubes did you use?0
I think about 3/4 of a tube per side. Be sure to mask off places where you don't want excess adhesive to get.0
3M 4200 black is removable. If you coat both sides and let set up until tacky, you can press together by hand and it will stay. Defender or West Marine.0
I'd decided that trying to glue the 34/5 running board rubber in one set up was going to be dodgy so I went for a 2 step process.
Step one is what you see in the photo above, the area under the plywood is being glued, the edge has no sikaflex under it.
First photo below shows the loose rubber edge after the board and clamps have been removed. Because the bulk of the rubber was now glued it was possible to fold the edge down without fear of things sliding around.
Second photo is the clamping set up for the edge.
Third photo is the finished running board.
Yes, the originals were rubber on metal made elsewhere which was layed on top of the running board proper. The attaching method is a little hard to explain but it involved lots of slots in the running board and little metal wedges rather than bolts. Some of the slots can be seen in the running board repair photo below. Having 2 sheets of steel one on top of the other created a water trap with the inevitable result.
Nice job. At home always the originals of 34 and in beautiful condition
