Removing Valve Covers
Old Fogey UK
I'm about to do a valve job.
I have removed both manifolds and the rear valve cover but can't slide or jiggle out the front valve cover because of the location of the oil pump.
Do I really have to take the oil pump off as well or am I missing something obvious ?
It must not be a 48-56 six cylinder...0
54coupe said:It must not be a 48-56 six cylinder...0
Assume you removed the ventilation pipe, correct? It should slide out without removing the oil pump. The valve cover gasket can get ‘welded’ to the block so you may need to pry it loose.0
I took them off without worry. Definitely the joints that stick
Otherwise; there is access through the right front wheel passage. A hatch with screws that gives access to the valve
You have to remove the timing cover bolt that hinders you moving the front tappet cover forward. Mover the cover outwards at the top and forward and wiggle it out.0
I think Hudson used feeler gauges to be sure parts had enough clearance to be removed and replaced.0
supercub said:I think Hudson used feeler gauges to be sure parts had enough clearance to be removed and replaced.
With my 1934 Eight, you can only get at the tappets to adjust them with the manifolds off and so "engine hot" clearances are nonsense.
Geoff's tip for getting the front valve cover off worked for me, by the way.0 -
Those little tricks of the trade are priceless.0
I'm sure there is a removable panel to get access to the rear tappets. I always adjust them hot. Most accurate way.0
Geoff said:I'm sure there is a removable panel to get access to the rear tappets. I always adjust them hot. Most accurate way.
On 34 and 35 cars there's a removable panel in the wheel arch that sort of lets you get awkward access to the front valve chamber but that's all.0 -
Of course you are right. The sweep of the guard gives enough room to get to the back ones. You only have to stand on your head, with your torso twisted 90 deg. and have three hands to perform the task, otherwise it is a piece of cake. Seriously though, the manifolds make little difference to the accessibility, as the exhaust sits on top of the block. Have fun!0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
