212 cast on side of block?
7XPacemaker
I just bought an engine and was told that it was a 175. I started degreasing the side of the block and found “212” cast into the block below the valve cover closest to the rear of the engine. What does this mean? I was under the impression that they didn’t cast cid numbers on the blocks. It is supposed to be a 40 or 41 engine. What do I have- a 175 or 212?
A 175 has a 4 1/8 stroke, whereas the 212 has a 5 inch stroke. Both bores are 3 in. The same block would have been used in both engines. The exhaust valve is directly under the spark plug so if you could get a stiff wire past the open valve to the piston at TDC and then at BDC maybe you could measure the difference in the wire length. A little more messy, but you could fill the cylinder with oil at BDC then pump it out and measure the cubes at 29.2 inches vs 35.3 if it was a 212. Or you could pull the head of course.
Might be easier to pull the pan and measure the stroke there.0
So, why the stamping? I understand everything that you said and knew all of that. I just don’t understand the stamping on the block. So, they all had that stamping?0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
