Getting to the short strokes 47 pickup
40indianssgmailcom
Some photos of the almost finished dash wiring. The glove box door is installed and the driver side is ready to install as soon as the led compatible turn signal and hazard flashers arrive. All lighting is now led and 12 volt system with voltage reducer to 6 volts for h2o temp and fuel gauges. Using a speedway 12 circuit wiring kit and as can be seen a more modern version of twin h power with dohc and twin carbs
nice. I like the Jag engine. Did you go the hole drive line or just the power plant ?0
4.2 liter xj6 engine, gm 350 trans, xj6 front and rear suspension. The engine is within 1/2" length of the 212 so looks appropriate in the engine bay unlike the overused sbc0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
