Fibre Timing Gear
I have a NOS Westinghouse fibre timing gear with a part number S-1032057.  I think it suits 1934 - 1936 Terraplane.
Is this correct?
Regards
Phil
  • Good for a wall hanger Phil, not much use for anything else unfortunately.
    Many years ago I used a NOS fibre one and only lasted a thousand miles or so, lucky it was an 8 cylinder so no damage.
  • When in doubt, make 'art'.
  • Phil - it should have three offset holes.  As long as it isn’t damaged and the fiber is solid you’ll be good to go
