1934 8 cylinder Over drive set up
Only the 1940 overdrive will fit the 1934 easily, but they are extremely hard to find. My suggestion is to either purchase one of the new rear end gears which are going to be made, or to replace the 1934 rear axle (and housing) with a more modern one, which has a better gear ratio. These would include certain MoPar and Ford rear axles from the 1960's and 70's. Of course, either the gears, or the entire axles, could be replaced with the original ones, in the future, if you wished to return the car to its original state.0
Jon B said:Only the 1940 overdrive will fit the 1934 easily, but they are extremely hard to find. My suggestion is to either purchase one of the new rear end gears which are going to be made, or to replace the 1934 rear axle (and housing) with a more modern one, which has a better gear ratio. These would include certain MoPar and Ford rear axles from the 1960's and 70's. Of course, either the gears, or the entire axles, could be replaced with the original ones, in the future, if you wished to return the car to its original state.
The later boxes are too bulky, they won't fit into the chassis they collide with the X frame. Been there tried that, it isn't going to work.
I don't know if anyone has looked at the possibility of rejigging one of the later boxes into the 1940 configuration.0 -
bob ward said:The later boxes are too bulky, they won't fit into the chassis they collide with the X frame. Been there tried that, it isn't going to work.
freddo, it seems you have enough gear to tackle this project but be warned there are many many hours in it. I'm happy to talk you though it.
This is an H8 with a Toyota overdrive 5 speed in a 35 chassis, the gearbox only just fits.
The wet clutch - flywheel, pressure plate and clutch plate - is retained and works off the original pedal. The bell housing is home made.
That's an impressive bit of engineering, Bob.0
Bob, That is awesome! I love the ingenuity of your setup!
That looks the like the way to go though the old 8 cylinder in mine does not even need 3 gears once I hit top it can almost go any where in top they are a great old engine
What model toyota gear box is that ? I see you have a modern reduction type starter motor as well0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
