Charge system
Recently pulled generator, installed new brushes, cleaned commutater and armatuer fresh grease in the bushing oiled front bearing. It had quit charging and suspect was voltage regulator. Found a NOS VR6002A regulator dat matches 6001B Generator. Generator is charging, test wire on either post and swiping other end to other post gets spark. Charge battery, test drive, overdrive kicks as it should, but turn on lights and not nuf juice to engage overdrive. Back to the shop, battery is dead. So something is amiss. Need guidance. 1950 Commodore 8,
Kim
Kim
Have you set the voltage? Must be 7.2 - 7.5 volts.0
How does that happen? Is that info in the shop manual? Thanks for your response0
Usually it's the battery . Recharge it fully and have it load tested.0
Yes, it's all in the manual. Too detailed to list here.0
Thank you Geoff.
Thank You LM0 -
Problem solved. If I'd taken the time to look in da shop manual, I may have it the solution. But, I've been spoiled by da folk on da forum. It's da quick fix.
Thank you very much,
Kim
The solution was adjusting da spring tension battery post on da regulator.0
- 111 Hudson 1916 - 1929
