Question for clarity on Ignition timing
If anyone can please tell me about how they set the ignition timing in their late 1930s cars. I have been doing it and always set the pointer in the middle between the mark on the fly wheel (as shown in the picture) but I read that "Timing is 5 degrees before topdead center. First on flywheel
ahead of "U.D.C. 1-6" should register pointer at flywheel
inspection hole."
So AM I to take that as I should put the pointer in line with the mark closest to the U.D.C 1-6 ? Or is where I have it set acceptable?
Set it to the first mark with a timing light at idle.0
Geoff, by first mark you mean the one closest to the 1-6?0
I like using a vacuum gauge, push its rubber pipe in to the wiper vacuum port on the inlet manifold then adjust the mixture and timing to get the highest reading. For the timing I get the maximum vacuum at idle then back it off a little by up to 1lb. I have got a thread on here from a few years ago discussing that. Works very well. In the old days they road tested and listened for pinging when flooring the throttle at low speed in top, backing off the timing until the sound was no longer heard. After vacuum gauge timing my 212 engine I heard no pinging at all and that is with good compression too, around 7.3:1. I didn't correlate that back to what that then showed on the timing marks, there was no need, but it would be interesting to know nevertheless.0
The right hand mark, which is the first one that comes into view..0
Thank you
Thanks all, the good doctor says where I have it is good0
Hey Geoff, so to be clear you suggest putting the pointer in which line? Red or blue??0
The blue line, at idle. Check that it advances nice and smooth as engine speed increases.0
Geoff, Even if I am setting it static as car doesn't run at the moment0
Old Fogey UK said:Geoff - did you agree with the advice of the ROC Geoff (see above) ?
Yes, David that is the first mark. Val, it will fire with this as a static setting, sure.0 -
Thank you0
- 112 Hudson 1916 - 1929
