Jet axles
JFromm
Are the axles the same for the automatic and the manual shift? If not, how can you tell the difference?
They are the same John. No difference.0
They are different ratios. There should be a tag on a cover bolt with the ratio on it. Auto was higher ratio than the manual0
Thanks for the help.0
