Removal Interior door latch handle 29 essex
supersixer
Does Anyone know how to get at the retainer ferrel to remove inner door latch handle I cannot see it it is behind a cover or the maybe the door handle? Thanks, Tony Silva Ossipee, NH
I mean it may be behind the door panel0
yes it is a pot metal nut behind the escutcheon and about a 9/16” wrench fits it.
they tend to crumble when loosened but I believe Geoff sells brass or bronze replacements.
Years ago a plumber taught me that brass fittings should be tightened ever so slightly to break loose the joint, then the galling is kept to a minimum. The same principle applies to this delicate pot metal.0
- 118 Hudson 1916 - 1929
