Template for mounting spotlight on a stepdown
FlimFlamMan
I've acquired a Unity Hudson spotlight and would like to mount it on my 51. Does anyone have a copy of the mounting template, I did a search and it's come up before, but could find no link to a template. The Unity website has a link for the template, but that link is dead.
Thanks
Thanks
You want mounting bracket 28L. Many people don't understand that if you don't have the correct bracket that you can't properly fit a spotlight. Spotlights for sale with no brackets are about useless.0
FFM, I have a copy of the instructions and a template for for that spotlight. I'll send you them, just PM your address. Lance is correct, you need bracket 28L which show up on Ebay occasionally.0
Thanks for the info, I do have the 28L bracket.
Thanks PM sentsnowshoe90aolcom said:FFM, I have a copy of the instructions and a template for for that spotlight. I'll send you them, just PM your address. Lance is correct, you need bracket 28L which show up on Ebay occasionally.0 -
FFM, be aware that you need a drill guide bushing that gets inserted in the 28L bracket before you drill. The bushing is 5/8" long, 5/8 OD and has a 1/2" ID to guide your 1/2 drill bit. Drill slowly because your drilling into the metal at an angle.0
