U-Joint part #
kamzack
Need current u joint part number for 1950 Commodore. Looked in Ken Cate's interchange and no luck.
Thanks,
Kim
Thanks,
Kim
I have a vintage Hudson swaps manual-interchange parts book (revised 1984) by Louis Backhus, J.R. For 1936-54 Hudsons it lists quite a few other car make universal joints that are compatible for these years. They include 62-72 Camaro, Chevelle, Chev II, Nova (exc Turbo Hyd), 55-70 Chev 1/2 ton 3 speed, 64-68 Mustang 6 & 8 cyl Auto Tr, and 45-67 Willys (exc Wagoneer). Perhaps someone else can vouch for these other makes.0
All 3 should work with Spicer/Dana 5-153XThis is what I successfully installed on my 1951 Super and the U-Joints on a 1950 Commodore should be the same.0
Thank you. I've come up with part #348 Moog. Local flaps has that listing.Had to hold onto the counter when he told me the price, nearly $30.00 each. Gonna do some diggin in my stash before consume a C note.
Kim0 -
That is the most common U joint around, used by everybody, better double check what you are asking for rock auto has them from about $5.00 to $14.00.0
Using the numbers posted above to cross I just bought three NAPA P369 for my 53 project. Haven't tried them yet, but they look right. This Hudson forum is mighty helpful.0
used the napa 369 in my 52 wasp
