Brake mods and gas line cleanup
The transition from Tredle-vac to a modern power brake setup did not go as smoothly as I had hoped. The hookups worked OK but when I pushed down and the peddle the results were less than what I expected. After doing a lot of reading and finally calling a tech support person at Wildwood it turns out that the master cylinder bore is the key, complicated by the weird bellcrank setup for the Tredle-vac. The bellcrank makes it difficult to calculate the pedal ratio. The bellcrank setup is not unique to Hudson as other automakers that used the Tredle-vac units also had strange mechanisms. I gave some serious thought to removing the bellcrank, but that would just create other problems, What I was able to do was to adapt a 7/8" bore Wildwood non-power MC, changing from the 1" aluminum one I had installed. This made a huge difference in pedal feel and stopping distance. If I could I would have tried an even smaller bore but there are few options that are less than 7/8". I also took the time to insert an auxillary vacuum pump and clean up the fuel pump to carb lines with stainless steel.
looks really good nice Dan!0
Dan, I did the same thing about 6 years ago and like you, I could not stop the car! Gave up, and went back to the under floor master cylinder using the disc brake kit that Matt Faust was selling. I found that the original Hudson power brakes with the original drum brakes stopped slightly better than the non power disc brake setup. however I like the no fade feature of the discs. Are you using a 7 inch vacuum cylinder with the master cyl? Did yo try the external vacuum pump before going to the present master cylinder?
I am using a dual 7in booster. I would have liked a bigger one, but the 7" just clears everything on the stock setup. I did take just a nip on the firewall support but it was just about a 3/16" of an inch. I initially did not use the external pump, but when I redid the master cylinder to 7/8" bore I went ahead and put it in as I had it plus the rest of the parts. It is in tandem with the engine vacuum and also connects to the original vacuum canister that the Tredlevac used. I still need to adjust the rear brakes and I think it will work even better. I also like having a dual MC as a safety backup since the Tredlevac option did not use the Hudson triple safe brake arrangement.
Solution for my '53>> https://goo.gl/photos/QEtE7t64Ebs53teC80
