Hill Holder
Can a duel master cylinder be utilized with a hill holder? If so, where to go to see an installation? The step down manuals do not show any hardware, mounting and/or any installation procedures.
it would be easier to install a line brake from a speed shop go's to the front brake line I m sure you could install a hill holder on the front line but you would have to reconfigure the hardware to make it work good luck my 2cents0
I think you can "T" into your front brake line and take it to the hill holder. Trick is mounting the arm to clutch shaft and adjusting it. Using copper/nickel makes creating brake lines much easier.
Kim0
- 112 Hudson 1916 - 1929
