step down dash gauges
blondwookie
This may sound odd but has anyone reset or moved the position of the fuel and temp gauges? I am thinking about moving my around so I can add an oil gauge to my car. I know that i will to redesign the gauge housing as well as the cover plate to allow the use of the additional gauge. I plan to also move the left and right turn signal a bit further out to allow for some extra room for the 3 gauges. Is this even possible to do and has anyone else done this?
There was a participant on this board in the past who designed and built replacement gauges for Hudson dash that added functionality in the available space. I failed to capture his contact info. Maybe others will be able to provide that to you.0
Bearing in mind there are three different dashboard layouts in Step-Downs.0
I have a 48 super six club coupe. Can I use a later dash?0
Yes the dashes unbolt and can be substitutedblondwookie said:I have a 48 super six club coupe. Can I use a later dash?0 -
Do you have pictures of the different kinds of dash gauge units0
I may be able to help... if you're patient and can put up with a guy with way too much on his plate... and poor planning skills... ? Currently working on a new set of revisions, ones that are not nearly as kludged together... Microcontroller driven electronic gauges.0 -
All of this is behind the steering wheel. Mine is in the center if the dash. How much would I have to change to put the dash pack behind the steering wheel0
What's the year? I may be able to make my center cluster work... or make adjustments as needed.0
Sorry Grim ? the dash shown is the same 1950 - 1953 install one of those instead of the existing dash... then use the Grim’ Great Gauges!blondwookie said:All of this is behind the steering wheel. Mine is in the center if the dash. How much would I have to change to put the dash pack behind the steering wheel0 -
My car is a 48 super six club coupe0
My car will be a full 12 volt system. I already have a working GM HEI in the engine. As well as well as a GM alternator.0
Ah, you have separate, round gauges in the center. I can probably work something up with those... I can also add additional functionality to the larger speedo and clock... If your interested send me a PM. Also, while I'm here - Glow!:
Need to check long term durability... this material is not known for temperature stability...0 -
Sent you a pm
- 97 Essex Super 6
