Seat Cushion
Has anyone had difficulty installing their bottom seat cushions & what did you find as the fix?
I ask because my 54 Hornet’s front bottom seat cushion is not at all wanting to go in. I’ve had 2 of us working on it at each side with no luck. As we get close on one side the other is 6-8” out. It seems to have a center spot that’s hanging up. Any help I’d appreciated.
What engine do you have? Sounds like something is blocking the bottom section0
You were right. I had to straighten some things out on it & then pull upon the back middle which was hanging up, then it went in.0
