Spark Plug Wires
Probably have to get a universal set and cut them to length.0
Suggest getting the correct cable, boots and crimp connectors at places like Brillman or Rhode Island Wiring Service. It’s very easy to make up a correct set for yourself.0
You can go to NAPA and buy a universal set with either straight or 90 degree boots. If you want a copper core set they probably have them also, or you can buy the stuff and make your own. Make sure you measure your longest wire to make sure there's at least one in the set.JFromm said:I am in need a set of spark plug wires for a 1954 Jet. Does anyone know if there is a comparable part number so I can purchase these at a local store?
Thank you0 -
What Toddh said. Also buy yourself a proper ratcheting spark wire crimping tool.0
Thanks for the help.0
I buy a set for a pre 1973 small block Chevy, and use the six shortest wires0
I bought mine from Rhode Island Wire but have also used YNZ out of California. Easy to make your own. And a good authentic look.0
- 111 Hudson 1916 - 1929
