1929 Essex rumble step wanted
rusty_apache
I need the bracketry as well.
Also looking to buy loose assorted Hudson nuts and bolts, hardware.
Do you want the lower step or the one mounted on the rear mud guard?
I want the elusive lower step and bracketry.0
We had 4 lower steps sand cast copied from a borrowed original at I think at about $30.00 each. the bracketry (support stem) we made at an engineering firm & cost rather more. This was some years ago & in New Zealand but hopefully the info may be useful.Be aware that the stem (bracketry) are mirror images between each side.0
Thanks for the information. I’m probably going to just wait for an old one to eventually turn up, if ever.ESSX28-1 said:We had 4 lower steps sand cast copied from a borrowed original at I think at about $30.00 each. the bracketry (support stem) we made at an engineering firm & cost rather more. This was some years ago & in New Zealand but hopefully the info may be useful.Be aware that the stem (bracketry) are mirror images between each side.I’m considering myself lucky for finding complete rumble seat cushions!0
- 97 Essex Super 6
