Inside antenna White escutcheon
Nevada Hudson
Anyone selling a white escutcheon, which is the part behind the antenna knob. Don't need the white antenna knob, as mine is perfect, just the plastic holder behind the knob. Don't want to buy both.
Ray, Contact Eschelman's to see if they will sell you the base escutcheon only.
http://partsbyemc.com/catalog/index.php?main_page=product_info&cPath=2&products_id=114
onerare39 said:Ray, Contact Eschelman's to see if they will sell you the base escutcheon only.
Already did that. That's why I posted on here.
Ray, for what it's worth..... I have found that if you get an antenna knob without the base ,it's likely the base you find won't fit without modification. The plastic used has shrunken over the years and warped so that if you don't have a matching set ,they likely won't mate up. You likely can machine one to work but that may be more than you want to do.0
The knob won't come off without totally destroying it, and since it is in excellent condition, I want to leave it.
