Front end alignment 1941 Bigboy
Taking the truck in on Thursday to get the front end aligned.
Looking for tips on it. Such as modern camber/ caster that work possibly better than back in 1941. Have a print out of what it is supposed to be.
Am I correct that the camber and caster are handled by adjusting only the outer upper control arm bushing? Or is there more adjustments than this?
All adjustment is at the top threaded bushing. The eccentricity of it adjusts the camber, and turning a complete turn back or frrward adjusts the caster. 1-1/14 camber and 0-1/2 deg. caster, with as close as possible variation each side.0
