Does this hub puller fit Hudson or Essex?
Can you provide ID ( internal diameter )and TPI threads per inch.
Using your ruler, looks like a little over 2 1/2 inch id.
But not good enough.
thanks, Hans
Thanks, Roy. I missed it by just reading the words.
1927 to 29 Essex uses 2 1/2 ID with 16 TPI
1930and 31 Essex uses 2 3/8 ID with 16 TP
I do not have earlier or later hubs or hubcaps to check.
Thanks , 14 is an odd tpi for a puller. A 16 gauge seems to fit , but the 14 is better.Hans said:Thanks, Roy. I missed it by just reading the words.
I do not have earlier or later hubs or hubcaps to check.0
- 112 Hudson 1916 - 1929
