Terraplane tranny question
I recently lost 2nd gear in my '32 Terraplane. Upon inspection, we discovered it was a
2nd and 3rd synchronizer snap ring that had broken. Is it possible to replace that snap ring without removing the tranny? Such as cutting a small piece off the snap ring so it will fit over and into the groove, without disassembly. Anyone ever do this?
If it is the internal snap ring that holds the second gear to the front shaft, there is no way to fix this without removing the transmission.0
The ‘32 had synchronizers?My ‘35 gearbox has no synchromesh.Regards, Tom0
Paradoxically, the Hudson-built transmission was called "Synchro-shift" in spite of the fact that it did actually have no synchronising mechanism. It did have constant mesh gears, with a sliding sleeve with dog teeth that engaged top and second gears. However, the 1932 Essex, and '32-33 Hudson had a one-off synchro transmission, though I have never seen none. It looks like a standard Borg-Warner unit to me, by the parts catalog.0
Special as configuration. My survivor Hudson EIGHT of 34 has the non-syncro speeds.Weird to have put syncros and to have made a comeback in the back.
