1953 Hornet Perimeter Rails/Under Rear Seat Section
bjgund
Hi Folks:
Does anyone out there in Hudsonland have a nice set of perimeter rails inner and/or outer, either new old stock, replacement stock or good used rails to fit a 53 Hudson Hornet? If you have something I can use & will be traveling to Hershey I could pick them up from you there o/a 10/8/21. I need both sides; the section below the wheel well & the curved piece leading to the front of the car
. Also, the metal around the hump under rear seat section. Email popgun7@comcast.net or
717-360-4910. Thanks.
(see photos).
(see photos).0
Having been on my website you know the scarcity of NOS pieces. The pictured items are the first and only set of Crash Part Rails I have seen in the 57 years I have owned Hudsons. The best bet is to have a metal shop fab you replacements the second option can be replacement pieces cut from a rust free donor.. yes there are such cars. Check with Al Saffrahn in AZ for donor car. Good Luck.0
