new here.. heres my 29 essex needs radiator
jimie8145
in Street Rods
This is my 29 Essex street rodded out disc brakes. 318 Mopar.
the original radiator has had the core replaced. the outside edges are what's rusting now.
This is the only thing that needs repaired to drive it to shows.
Any suggestions on where to get a radiator. They are not the same as a model t.
Thanks
jim
Thanks
jim
Wildrick Restoration (wildrickrestorations.com) try these guys. Doug is the great with Hudson cars and has lots of parts and can direct you to where you may get it if he doesn't have it. BELLINGHAM AUTO SALES - Hudson Motor Cars also try this as Ed has lots of parts Hope this helps
Easy enough to repair the framework around the radiator, any good welder could do this.0
Thank you0
