Bearings for straight 8 engine?
Here’s what I’m wondering, has anyone successfully done inserts for the straight 8 Hudson engine?
Rods are originally babbitt & mains were inserts but for either my 37 or 49 straight 8 engine, I don’t see anything out there for the main inserts. So what are people doing, other than a 308 engine replacement or spending a boatload of cash to have everything babbitted?
Yep, when I rebuilt my 8 back in the late 80s even then main bearing inserts were not easy to find.0
The problem is that all main bearing journals are a different diameter, and new or remetalled bearings have to be line bored. No easy way out I'm sorry.0
Main bearing inserts used to be available in standard oversizes but in limited quantities - not seen any . Somewhat more common were mains in an oversize called "semi" which need to be line bored to size to fit the crank. Mains and rod bearings are all babbit - anyone know of a shop that can do this today ? I remember the enjoyment of driving a 1947 and a 1950 straight eight Hudson - with overdrive - you could pretty much stay in second gear and even start out in that! Very smooth and quiet. Gert0
Unfortunately the death of Hudson splasher engine’s is looming near…0
Not really. there are still people out there who can re-metal and line bore main bearings.0
Yeah, there are still some in the States but the number keeps dwindling. Unfortunately unlike model T’s where some of those builders do hundreds of rods/mains a week, there are just so few who do Hudson’s. “Their prices” definitely are becoming an obstacle to rebuilding the original engine unless one is really “ “ bent on rebuilding the original engine. I wish there was some way to easily do inserts on the mains & cams then one would only have to send off the rods to be babbitted. Just my thoughts as I get ready to tear into the 1949 254ci straight 8 in the garage to see what I really have…0
There’s a guy by the name of Bill Coleman in Baltimore, MD who did my engine out of my ‘46 Super Eight coupe a number of years ago. He’s still around as far as I know. He had my mains and rods poured by a company Pittsburgh and then he line bored it. At the time I was told he had the only boring bar in that part of the US long enough to do my straight 8. He also assembled the short block as well. It was superbly done and you didn’t know it was running unless you put the hood up0
Line boring is still a common process, how do you think they do diesel engines? Any really excellent rebuild includes line boring, as far as who does pouring shells semi. you got to make an effort to find someone.
Tombia you are absolutely on point! Hudson engine building is and continues to be an a labor of ❤️!0
- 112 Hudson 1916 - 1929
