Oil tube? 53 Hornet
I posted a week or so ago about oil filters and I forgot/ failed to think about what setup I have on the car .
I have a rubber tube connecting the ports usually used for the oil filter.
Should this line be plugged for better pressure ?
Am I starving the bearings from there oil ?- I doubt there is a restriction in that line.
I would remove the tube and just put in the 1/8” NPT steel or brass plugs.0
That’s what I was thinking . Thanks!0
- 112 Hudson 1916 - 1929
