ISO voltage regulator 6V positive ground
JML55
Anyone has a source for new voltage regulator for 1935 Terraplane or has one for sale?
Thanks, JM
Thanks, JM
It may be worth your while to contact this company: https://brillman.com/
Your 35 came with an Autolite generator and VR unit. Suggest you try to match a similar Autolite VR unit to your generator so you can approximate the correct charging rate and amperage.0
Terraplane special or Deluxe? They have different systems.0
