Looking for soft shocks
54Hollywood
Hi everyone. Looking for some soft shocks for both the front and rear for our '54 Hornet. The ones on the car now are very firm with a harsh ride and it's not a pleasant ride. Recommendations are appreciated, thanks.
Tim in WI.
Tim in WI.
Hi Tim,
You might want to try an adjustable pneumatic shock. These are the one that are adjusted by using machine air out of a compressor. That might give you the ride you're looking for but definitely search the forums for the experiences of others.
Good luck!
Ray0 -
Shocks Reg Stepdown Front, 7 3/4 - 12 Monroe (Amazon $26) 5751 Shocks Reg Stepdown Rear Monroe 31094
Tim, I'm curious: are your present shocks hydraulic, or gas?0
Shocks (Front, 40-54 , Exc. Jet) Interchangeable with:
71-79 AMC Gremlin, Javelin, AMX
49-54 Chevrolet (Exc. Corvette)
53-62 Chevrolet Corvette
74-78 Chrysler Full Size
52-56 Ford (Exc. Station Wagon)
76-79 Plymouth Volare, Dodge Aspen
61-73 Volvo 1800Hudson Swaps Manual
www.hudsonrestoration1948-54.comShocks (48-54 , Front) PA 15740132 Advance Auto Parts South Texas HET Chapter January 2018 Newsletter
south-texas-hudson.orgShocks (48-54 , Front) 3008 Monroe Heavy Duty 1 3/4" Rod, Front shocks should extend from 7 3/4" to 12" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Front) 51272 Rare Parts Shocks (48-54 , Front) 5751 ST Monroe Sense-Tracs Front shocks should extend from 7 3/4" to 12" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Front) 82026 Gabriel Front shocks should extend from 7 3/4" to 12" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Front) 82028 Gabriel Gas Shock Front shocks should extend from 7 3/4" to 12" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Front) 94015 NAPA WTN recommendation Shocks (48-54 , Front) 1200 Wildrick With shock plates. Part# 1199 w/o shock plates. Shock plates are part# 1198. Wildrick Rubber Parts
http://wrphet.com/Shocks (Rear, 48-54 , Exc. Jet) Interchangeable with:
50-51 Cadillac
65-68 Cadillac
65-68 Cadillac El Dorado (Exc. commerical chasis)
57-59 Chevrolet Truck
49-54 Ford Station Wagon
55-59 GMC 1/2 & 3/4 ton Truck
63-73 Jeep Cherokee Wagoneer (Exc. Indep. Susp.)
47-55 Kaiser
49-51 Mercury
41-48 Pontiac
58-60 Pontiac
51-56 StudebakerHudson Swaps Manual
www.hudsonrestoration1948-54.comShocks (48-54 , Rear) PA 15740070 Advance Auto Parts South Texas HET Chapter January 2018 Newsletter
south-texas-hudson.orgShocks (48-54 , Rear) 3035 Monroe Heavy Duty 1 3/4" Rod, Rear shocks should extend from 13 1/16" to 21 15/16" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Rear) 37029 ST Monroe Sense-Tracs Rear shocks should extend from 13 1/16" to 21 15/16" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Rear) 82154 Gabriel Rear shocks should extend from 13 1/16" to 21 15/16" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Rear) 81147 Gabriel Gas Shock Rear shocks should extend from 13 1/16" to 21 15/16" total Hudson Parts Interchange
www.hudsonrestoration1948-54.comShocks (48-54 , Rear) 94080 NAPA South Texas HET Chapter January 2018 Newsletter
south-texas-hudson.orgShocks (48-54 , Rear) 31094 Monroe Installed on my car. Top rubber bushing MUST be trimmed to fit in bracket (cut where bushing starts to round corners). Shocks (48-54 , Rear) 51246 Rare Parts Shocks (48-54 , Rear) 51950 Rare Parts Heavy Duty Shocks (48-54 , Rear) 1201 Wildrick Wildrick Rubber Parts
http://wrphet.com/
Hello again. I do appreciate all your fine comments. Our car has the Monroe 5751 shocks on the front and the Monroe 31094 shocks on the rear. I've heard that the 5751 is a good Hudson shock but I'd like to try something else. In my view, the 5751 is very firm so I'll investigate your suggestions.0
