Jet Clutch
As I am finishing up on my 53 Hornet, I will soon be starting on my next project. My mom's 54 Jet 2 door that was parked 40 years ago after the clutch went out. After a quick internet search I do not find clutch discs and pressure plates for the Jet. Is there a interchange for the clutch disc and do you typically recondition the pressure plate?
I might have a disc. I'll check when I get home from work.0
Same plate used by Ford, Studebaker, Dodge, and others. Is a Borg an Beck unit.0
Rochester Brake and clutch will have what you need. They are located in Victor NY.
Phone is 585-424-37170 -
Thanks for the information guys. A quick look on Dennis Carpenter lists the Ford clutch as 9.5" and Hudson lists it as 9.125". Is the 9.5" pressure plate correct for the jet flywheel? Also a quick gooe search for Rochester Brake and clutch shows they are out of business.0
Try rochesterclutch.com should pop right up0
Jet clutch is 9.125", 10 spline.0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
