Identifying the correct crank gear for an aluminum timing gear
I previously talked about doing preventive timing gear work on my 1942 eight. I have only had it about 6 months and while it does run well I dont know what type of cam gear it is currently running, fiber or aluminum. (why pull the cover until you are ready to replace something?)
It came to me with a box of loose parts in the trunk and I just recently went back and looked through them. Turns out there are 3 fiber gears in there and an aluminum cam gear. <great!> and one crank gear. (all brand new)
So, I can now remove the covers and if it is a fiber gear I will certainly want to change it to the aluminum version.
HOWEVER, I understand that the crank gear is different for fiber and aluminum. How do you identify if a crank gear is correct for an aluminum or fiber type cam gear? Are there numbers or other things to look for?
No, the crank gear is the same for both fibre and alloy. The difference was before 1941 the angle of the teeth was different, so you can't intechange with the earlier versions.0
The Hudson gears I have, have a part number on them.0
As a reminder, the front engine support plate needs to be modified to accept the new aluminum gear. The bolt hole directly behind the timing gear needs to be chamfered to allows the use of a flat head machine screw in place of the bolt to provide clearance.0
I would think you could fully mesh the teeth of two gears together, and see if the faces of the gears were parallel... if not, the angles are not the same.0
You could also set the gear on a surface table and use a protractor to determine the angle0
Mesh the gears and see if they bottom in each other. if there is a large gap at the bottom they are mismatched.0
Old Fogey, If you need or want it, I can send you a copy of the original instruction sheet which came with the circa 1940s gear change kits. A fairly simple process...the only difficulty I had was removing the confounded harmonic balancer.0
You can visually determine the gears too, but you have to have two different types to note the difference. The original gears were 14-1/2 deg pitch. Now to clear confusion, the pitch is not the angle at which the gears are cut in relation the front face, but pitch is the angle they are cut in the groove, Hence the earlier gears have a wider notch at the bottom of the groove, and thinner peak, if you can visualise this. The later 20 deg. gears have a narrower groove at the bottom, and thinner peak, hence there is more material at the base, which makes it stronger. The earlier gears used to break off at the base. I probably haven't described it sufficiently, but if you have a pair of gears, they should mesh deeply, with very little light showing between the tooth and base. Hope this helps.0
Here’s a pic of a set I have. Both are marked 20. You can the 20 on the larger cam gear near the crossed out 10 on my desk blotter.
Thank you for the pic, it shows exactly what I described as full depth mesh. It also shows the thicker metal at the base of the teeth.0
When I place and early cam fiber gear flat on the bench and the later cam fiber gear next to it, the later gear is thicker.
I Identify them that way.
While I have crank gears for use with the Aluminum cam gear, I have never compared the crank gears for thickness in the same way.
Goeff, perhaps you can provide my missing info.
Are the early and late crank gears the same thickness?
This may help to Identify gears more quickly.
Hans0 -
Hans, this is a separate issue. The '32 to '35 models used a thinner gear. In '36 the gear was 1/8" thicker, but all gears up to and including 1940 were 14-1/2 deg. pitch. They changed the pitch to 20 in 1941, and post war they used alloy gears.0
I sent the illustrated instruction sheet to you as an email attachment. Let me know if you do not receive it.Old Fogey UK said:
Yes please, I'd really appreciate that !hasktavern1 said:Old Fogey, If you need or want it, I can send you a copy of the original instruction sheet which came with the circa 1940s gear change kits. A fairly simple process...the only difficulty I had was removing the confounded harmonic balancer.0 -
Thank You, Geoff, for your info.
I sent it to the email listed for you in this forum, beginning with "del".0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
