Opportunity to bring back the Chuck and Rudy Performance Head
Will do thanks. Yes, I know it is more than I had hoped for when I started looking at this. But with so few parts to spread the tooling and upfront costs over it is what it is. The other issue is that aluminum alloy prices have now almost doubled from what they were 9 mo. ago! I am submitting an ad to the WTN today to see if we can swing a few more interested parties.
I hope to get back on the manifold project soon as well.0 -
I'm not in a hurry, but it sounds like we should get a batch done before alloy prices double again.
InlineEric said:I'm not in a hurry, but it sounds like we should get a batch done before alloy prices double again.0
Time line is about 12 weeks after a go.0
At 17! Look for an ad in the Jan/Feb WTN.0
I'm interested to have one and put it on my 54 Super Wasp, but I don't quite know if it's 7/16 or 1/2 that I need. Any quick way to check this or do I have to remove at least one head bolt to find out ?0
Providing you have a stock 262 in your Wasp it would be 7/16. Unless it is a '55/'56 or reworked earlier Hudson I6 they are 7/16. 7x, '55 and '56 308s were 1/2". We will probably make the heads with 7/16 std which would allow them to be opened up to 1/2 if desired.
We have 20 heads reserved so far, but are hoping for at least 30 to get the price down more. We also did some redesign work on the original design to beef up the strength for anyone wanting to use pressurized options, ie. turbo/supercharging.0 -
I've done some research through the old papers and bills that came with my car and didn't find any mentions regading the engine's head, so I'm assuming that it is stock.
I will take one head if I didn't mentioned it.
Also, what are the precautions to take when installing it as we all know that aluminium alloy doesn't really like any other alloy?0 -
Hi 50C8DAN, I will take one. VicTor Zamora thez@verizon.net0
This thread should give you the info you need. This head will not be any different than a stock aluminum Hudson head as far as keeping your head healthy with the cast iron block.
https://openforum.hetclub.org/discussion/366869/308-aluminum-head-w-0-5-head-bolts-gasket-and-torque-setting
With you two guys we are at 22! 8 to go.0
50c8dan,
What is the part # for the metal Al. head gasket with 7/16 studs? Thanks, Fred0 -
When I installed my Al head I used the 7570SPT PRO TORQUE HIGH BOND HEAD GASKET 1951-54 308 ($95.00) from Dale Cooper and I have had no issues with it leaking. However many use the Best Gaskets w/ Permabond and have had good results as well.0
50C8DAN said:This thread should give you the info you need. This head will not be any different than a stock aluminum Hudson head as far as keeping your head healthy with the cast iron block.
This is where I got all my answersAdditionally, I've always used the Best Gasket (722/723 depending on head bolts) as suggested by Russ and Dale. Some commenters on that thread shy away but we've had lots of long, healthy life on iron and aluminum heads with those gaskets. And Russ always said not to torque aluminum heads more than about 65 ft-lbs (unless you have insane compression ratios).
I believe the proposed head has a very different design than what Wildrick sells.0
syddthekidd said:Why are we trying to reinvent the wheel when Wildricks is selling performance heads?0
Please see photos and information on the Clifford combustion chamber, which is based on old technology, and the newer vortex design, they are very different.0
50c8dan, Will the new finned AL. head be able to have an A/C mounting plate bracket, on top of the head, utilizing the two head bolts on the driver side front? Thanks, Fred0
Fred I am not sure I understand the question. If the current stock head does I am not sure why this one would not? Or are you asking for a mounting flange modification?0
50c8dan, I was concerned that the fins would be strong enough to accomendate the hold down plate for the A/C bracket. The A/C bracket is a flat plate mounted to the top of the head by the two front head bolts on the driver side. A vertical plate then goes down the side of the block and mounts to the generator mounting holes. A/C compressor and alternator mount to this vertical plate.
Also is this Al. head 2 inches thick as the iron head is?0 -
TwinSupercharged said:50c8dan, I was concerned that the fins would be strong enough to accomendate the hold down plate for the A/C bracket. The A/C bracket is a flat plate mounted to the top of the head by the two front head bolts on the driver side. A vertical plate then goes down the side of the block and mounts to the generator mounting holes. A/C compressor and alternator mount to this vertical plate.
I cannot really answer if it will work as-is or not. The other option is to make some filler blocks that fit between the fins to help strengthen the area. However, the fins are not really that thin so I think they may be OK.0
thanks to 54coup and 50c8Dan for the response.
50c8Dan, will the new Al head be 2 inches thick as is the iron head? Thanks Fred0 -
If you check a check a stock head it is probably a bit shy of 2" but yes the new head will measure 2" unless you decide to mill it.0
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 597 Vehicles
