1946 super windshield removal
Pretty simple. Take the screws out of the metal surrounding the side you want to remove, (on the inside) including the center divider. That will release the rubber channel holding the glass. However, it may be stuck to the metal in front, so be careful. You may have to get a helper to hold it while you use a metal or plastic scraper between the metal and rubber channel on the outside.0
This is covered in detail in the 42 to 47 Mechanical Procedure manual, page 301/3020
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
